4.2.2010, 9:51
![]() Описание: Программа для сохранения в PDF с веб-страниц, электронной почты, документов и тд. Convert or "print" to PDF directly from your Pocket PC or Smartphone. Key Features: -Print to PDF from variety of document types: -Contacts -Appointments -Tasks -RTF -Text -HTML -JPG -BMP -PNG -GIF -Encrypt documents for added security. -Select page sizes and margins or allow the software to automatically select the best fit. -Integrated with Pocket Outlook, Pocket Internet Explorer, and File Explorer for easy use. *Mobile devices have limited processing power and memory. Because of this the PDF documents are not guaranteed to appear exactly like they do on the device. The software will attempt to preserve the document content and structure as best it can with the available resources. Требования .NET Compact Framework 2.0 Цитата Версия: 1.0 Категория: Офис Совместимость: WM5,6 ******
Текстовая версия | Сейчас: 5.6.2026, 16:36 |
