> G-Alarm
сообщение 2.2.2010, 10:18
Alarm - это бесплатный будильник для вашего коммуникатора,кпк или смартфона.
Главная особенность этого будильника:
Чтобы его выключить Вам необходимо провести шарик по простенькому лабиринту или же решить математическую задачку.
Изменения:
2.1.1 (2009/06/13)
[ADDED] Support for midi (.mid) files
[ADDED] Option: Always turn on phone radio after an alarm
[FIXED] Alarm doesn't go off on some devices (introduced in 2.1)
[FIXED] *Hopefully* PIN window is still visible although PIN is entered
[FIXED] Installation hangs on some devices
[FIXED] G-Alarm ignores the format of a talking clock
[FIXED] Today plugin does not display special chars of some languages
[FIXED] G-Alarm freezes after preview of a sound file
[UPDATED] Languages: English, German, Polish, French, Italian, Romanian, Dutch, Korean, Swedish, Finnish, Czech, Japanese, Catalan, Spanish
2.1 (2009/06/03)
[FIXED] Emergency sound file can't be found under some circumstances
[FIXED] Some Today plugin problems
[FIXED] Mazes don't end on some devices
[FIXED] Crashes due to the tilt sensor on Samsung devices
[ADDED] Talking clock
[ADDED] Today plugin: skinable bells
[ADDED] Hidden option: Change the id of the vibration module to use
[ADDED] Scrollbars are always visible if you're able to scroll
[UPDATED] Elongated trial time until 2009/06/30
[UPDATED] Languages: English, German, Portuguese, Romanian, French, Italian
Версия: 2.1.1
Совместимость: WM5,6 (G-Sensor)
RSS Текстовая версия Сейчас: 26.6.2026, 3:53
